Introducción
The front case of the guitar is primarily decorative, but removing it is vital to access the internal components of the guitar. This guide will show you how to replace the front cover of the guitar.
Qué necesitas
Remove the strap by pulling it off of the mounts located on the body and neck.
Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
Gently lift up on the auxiliary port to remove it from the case.
Remove the two 10mm Phillips #1 screws from the RJ-14 connector board.
Lift the RJ-14 connector to remove it from the case.
Use a screwdriver to remove the 10 mm Phillips #1 screws from the key sensor board.
Lift up on the key sensor board to remove it from the guitar neck.
Use a screwdriver to remove the four 14mm Phillips #1 screws around the perimeter of the strum bar sensor board.
Lift up on the strum bar sensor board to remove it from the case.
Remove the two 7mm Phillips #0 screws.
Using your fingers, remove the black wire retainer.
Remove the four 10mm Phillips #1 screws around the perimeter of the motherboard with a screwdriver.
Lift the motherboard to remove it from the case.
Remove the four 12mm Phillips #1 that connect the body to the neck using a screwdriver.
