Saltar al contenido principal
RedOctane X-Plorer Auxiliary Port Replacement
Qué necesitas
  1. RedOctane X-Plorer Auxiliary Port Replacement, Rear Case: paso 1, imagen 1 de 2 RedOctane X-Plorer Auxiliary Port Replacement, Rear Case: paso 1, imagen 2 de 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Auxiliary Port Replacement: paso 2, imagen 1 de 3 RedOctane X-Plorer Auxiliary Port Replacement: paso 2, imagen 2 de 3 RedOctane X-Plorer Auxiliary Port Replacement: paso 2, imagen 3 de 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Auxiliary Port Replacement: paso 3, imagen 1 de 3 RedOctane X-Plorer Auxiliary Port Replacement: paso 3, imagen 2 de 3 RedOctane X-Plorer Auxiliary Port Replacement: paso 3, imagen 3 de 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: paso 4, imagen 1 de 3 RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: paso 4, imagen 2 de 3 RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: paso 4, imagen 3 de 3
    • Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
    • Gently lift up on the auxiliary port to remove it from the case.
Conclusión
Riley
Miembro Desde 04/18/18
649 Reputación
7 Guías creadas
Equipo
Cal Poly, Team S17-G1, Livingston Spring 2018 Miembro de Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 Miembros
9 Guías creadas
Un comentario
What does the neck have to do with this? You mention it in the intro and step 3, but I don’t get why you’d need to open up the neck at all for this repair.
Tuesday - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 16
Todo El Tiempo: 1,158
