Introducción
Resetting the center value, in case the steering wheel is no longer centered correctly in game.
Connect and start the steering wheel.
If you are on a PC, set the rotation angle to 1080° from the Thrustmaster control panel.
If you are on a console, manually set the rotation angle to 1080°.
To do this, press the “Right D-PAD + MODE” buttons simultaneously to increase the angle of rotation. The base LED should flash 5 times.
Turn the steering wheel all the way to the left, as far as it will go.
Turn the steering wheel all the way to the right, as far as it will go.
Recenter your wheel.
Press the buttons to recenter the steering wheel. These buttons vary depending on what model you have, but you can find out which to use here.
Once the central value has been reset, the LED on your base should then briefly change color, validating the procedure.
You can then verify whether the wheel is steering properly using the Thrustmaster Control Panel.
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
