Saltar al contenido principal
Reattaching the GEN 2 Wheelchair Foot Support
Qué necesitas
  1. Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: paso 1, imagen 1 de 3 Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: paso 1, imagen 2 de 3 Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: paso 1, imagen 3 de 3
    • Slide the footrest sockets down as shown and use a 10 mm wrench to tighten the bolts at the desired height.
  2. Reattaching the GEN 2 Wheelchair Foot Support: paso 2, imagen 1 de 1
    • Screw in the bolt to the top socket to secure the height of the footrest.
  3. Reattaching the GEN 2 Wheelchair Foot Support: paso 3, imagen 1 de 2 Reattaching the GEN 2 Wheelchair Foot Support: paso 3, imagen 2 de 2
    • Screw in the bolt attaching the footrest to the frame.
    • Screw in the lower bolt to the footrest.
Conclusión
Check that the footrest is at the desired height. If the footrest is still uncomfortable start the guide over again from step 1 using a different height to tighten bolts.
Kali Slaughter
Miembro Desde 04/19/13
207 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 14-8, Maness Spring 2013 Miembro de Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 801
