Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
We will go through all of the steps you need to preform to remove the rear wheel from your bike. This is used in repairing many parts of the bike so it is very important you know how to do this.
  1. Flip the quick release lever on the wheel. Flip the quick release lever on the wheel.
    • Flip the quick release lever on the wheel.
  2. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  3. Squeeze the brake arms together and lift the brake cable from the caliper arms.
    • Squeeze the brake arms together and lift the brake cable from the caliper arms.
  4. Hold the wheel to the ground, and pull the bike frame up and away to remove the wheel from the bike.
    • Hold the wheel to the ground, and pull the bike frame up and away to remove the wheel from the bike.
Conclusión
2 personas más completaron esta guía.
Travis Tonder
Miembro Desde 05/10/10
2,622 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 5-13, Maness Fall 2010 Miembro de Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 3,031
