Saltar al contenido principal
Realspace EC600 Office Chair Lift Cylinder Replacement
Qué necesitas
  1. Realspace EC600 Office Chair Lift Cylinder Replacement, Lift Cylinder: paso 1, imagen 1 de 2 Realspace EC600 Office Chair Lift Cylinder Replacement, Lift Cylinder: paso 1, imagen 2 de 2
    • Position the chair so that you have access to the underside of its base.
    • Some of the parts will be coated in oil and can create a mess in your workspace.
  2. Realspace EC600 Office Chair Lift Cylinder Replacement: paso 2, imagen 1 de 2 Realspace EC600 Office Chair Lift Cylinder Replacement: paso 2, imagen 2 de 2
    • Remove the spring retaining clip by lifting with the flathead screwdriver and sliding it off with your thumb.
    • Remove the washer that was underneath the clip.
  3. Realspace EC600 Office Chair Lift Cylinder Replacement: paso 3, imagen 1 de 1
    • Lift the base off of the lift cylinder.
    • The rubber bumper, washers, and bearings may fall off during this step.
  4. Realspace EC600 Office Chair Lift Cylinder Replacement: paso 4, imagen 1 de 1
    • Remove the rubber bumper, washers, and bearings.
  5. Realspace EC600 Office Chair Lift Cylinder Replacement: paso 5, imagen 1 de 1
    • Remove the lift cylinder cover.
  6. Realspace EC600 Office Chair Lift Cylinder Replacement: paso 6, imagen 1 de 2 Realspace EC600 Office Chair Lift Cylinder Replacement: paso 6, imagen 2 de 2
    • Spray WD-40 around the base of the lift cylinder.
    • Loosen the cylinder off the chair by rotating it with the pipe wrench.
    • If you are having trouble rotating the the cylinder off, then wrap painter's tape around where you are rotating the cylinder.
  7. Realspace EC600 Office Chair Lift Cylinder Replacement: paso 7, imagen 1 de 2 Realspace EC600 Office Chair Lift Cylinder Replacement: paso 7, imagen 2 de 2
    • Remove the old lift cylinder.
    • Press the new cylinder into the chair.
    • The ends of the cylinder will have oil on them so they may make a mess.
  8. Realspace EC600 Office Chair Lift Cylinder Replacement: paso 8, imagen 1 de 1
    • Push the lift cylinder cover onto the new cylinder.
  9. Realspace EC600 Office Chair Lift Cylinder Replacement: paso 9, imagen 1 de 2 Realspace EC600 Office Chair Lift Cylinder Replacement: paso 9, imagen 2 de 2
    • Push the rubber bumper, washers, and bearings onto the lift cylinder.
    • The order should be from the chair to the rubber bumper, washer, bearings, and then the other washer.
  10. Realspace EC600 Office Chair Lift Cylinder Replacement: paso 10, imagen 1 de 1
    • Set the base over the lift cylinder and press it onto the cylinder.
  11. Realspace EC600 Office Chair Lift Cylinder Replacement: paso 11, imagen 1 de 2 Realspace EC600 Office Chair Lift Cylinder Replacement: paso 11, imagen 2 de 2
    • Place the washer at the end of the cylinder.
    • Slip the spring retaining clip onto the end of the cylinder.
Conclusión
Finally, flip the chair back over and press down on the seat of the chair to make sure the cylinder is completely pressed in.
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 18
Ultimos 30 días: 67
Todo El Tiempo: 2,339
