Saltar al contenido principal
Razer Wildcat Xbox One Controller Disassembly
Qué necesitas
  1. Razer Wildcat Xbox One Controller Disassembly, Remove grip plates: paso 1, imagen 1 de 2 Razer Wildcat Xbox One Controller Disassembly, Remove grip plates: paso 1, imagen 2 de 2
    • Use a plastic pry tool to remove the grip plate from each side
    • The plate will release away from the back, not to the side
  2. Razer Wildcat Xbox One Controller Disassembly, Remove the back plate: paso 2, imagen 1 de 3 Razer Wildcat Xbox One Controller Disassembly, Remove the back plate: paso 2, imagen 2 de 3 Razer Wildcat Xbox One Controller Disassembly, Remove the back plate: paso 2, imagen 3 de 3
    • Cut the sticker covering the center screw and remove it (PH #1)
    • Remove two screws from each grip (PH #1)
    • Use a plastic pry tool to remove rear plate from the controller
    • The three remaining screws on the back plate are PH #1
  3. Razer Wildcat Xbox One Controller Disassembly, Disassemble the board: paso 3, imagen 1 de 2 Razer Wildcat Xbox One Controller Disassembly, Disassemble the board: paso 3, imagen 2 de 2
    • Remove the M1 & M2 bumpers with two PH #1 screws (red)
    • Unplug the four rumble motors (green)
    • Unscrew the board from the controller with two PH #2 screws (blue)
    • Carefully flip the board until you can get to the ribbon cable
    • Flip the gray clip up to release the ribbon cable
  4. Razer Wildcat Xbox One Controller Disassembly, Remove the triggers: paso 4, imagen 1 de 3 Razer Wildcat Xbox One Controller Disassembly, Remove the triggers: paso 4, imagen 2 de 3 Razer Wildcat Xbox One Controller Disassembly, Remove the triggers: paso 4, imagen 3 de 3
    • Remove the two PH #00 screws to remove the trigger brackets
    • Slide the trigger pin out just enough to remove it, leave the spring attached
    • The three remaining screws on each trigger are PH #1
  5. Razer Wildcat Xbox One Controller Disassembly, Remove the bumpers: paso 5, imagen 1 de 1
    • Remove the bumper assembly from the controller
    • The bumpers detach with two PH #1 screws
Conclusión
2 personas más completaron esta guía.
Drew
Miembro Desde 11/13/24
181 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 74
Ultimos 30 días: 176
Todo El Tiempo: 312
