Saltar al contenido principal
Razer Ouroboros Scroll Wheel Replacement
Qué necesitas
  1. Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: paso 1, imagen 1 de 3 Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: paso 1, imagen 2 de 3 Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: paso 1, imagen 3 de 3
    • Use a Phillips #00 screwdriver to loosen the two captive screws from the bottom of the mouse.
    • Slide the palm rest out of place.
  2. Razer Ouroboros Scroll Wheel Replacement: paso 2, imagen 1 de 2 Razer Ouroboros Scroll Wheel Replacement: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Remove all of the stickers on the back of the mouse. After doing so, you should see six screws on the back of the mouse.
    • Use the Phillips #0 Screwdriver to remove all six of these 4mm screws.
    • Use the Phillips #00 Screwdriver to remove these two, 3mm screws.
    • Slide the side panels off of the mouse.
    • Use your tweezers to take the lock switches off of the mouse.
    • Using the T6 Torx screwdriver, remove the two bottom 4mm screws as indicated in the second picture.
  3. Razer Ouroboros Scroll Wheel Replacement: paso 3, imagen 1 de 3 Razer Ouroboros Scroll Wheel Replacement: paso 3, imagen 2 de 3 Razer Ouroboros Scroll Wheel Replacement: paso 3, imagen 3 de 3
    • Using the T6 Torx screwdriver, remove the two 4mm screws hidden in the deep holes indicated in the first picture.
    • Slide the top panels off of the mouse.
    • Flip the mouse over, and the mouse casing should come off.
    • There are some connectors connecting the casing to the motherboard. They should slide off. Just be careful not to break them.
  4. Razer Ouroboros Scroll Wheel Replacement: paso 4, imagen 1 de 3 Razer Ouroboros Scroll Wheel Replacement: paso 4, imagen 2 de 3 Razer Ouroboros Scroll Wheel Replacement: paso 4, imagen 3 de 3
    • Locate the 4mm screw indicated in the first picture, use a Phillips #00 Screwdriver to remove it.
    • Locate the two 4mm screws in the second picture, and remove those two with a Phillips #0 Screwdriver.
    • Now, you may remove the board that holds the scroll wheel and its components. Simply slide the wheel out and replace it.
    • Take note of the orientation in the final picture so that you can place the wheel back correctly into its mechanism.
Conclusión
5 personas más completaron esta guía.
Preston Darling
Miembro Desde 07/26/16
372 Reputación
2 Guías creadas
Equipo
1Guía Comentario
Hello, one question, did the scroll click break, is it the same procedure?
Jorge Bestani (Ayman) - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 23
Todo El Tiempo: 4,314
