Saltar al contenido principal
Razer Ouroboros Lock Switch Replacement
Qué necesitas
  1. Razer Ouroboros Lock Switch Replacement, Left and Right Trigger Switch: paso 1, imagen 1 de 2 Razer Ouroboros Lock Switch Replacement, Left and Right Trigger Switch: paso 1, imagen 2 de 2
    • Flip the mouse over and remove the stickers on the back of the device. These stickers are hiding the screws we need to remove.
    • Locate and remove the captive screws to remove the hand rest.
  2. Razer Ouroboros Lock Switch Replacement: paso 2, imagen 1 de 2 Razer Ouroboros Lock Switch Replacement: paso 2, imagen 2 de 2
    • Locate and remove the six 4mm screws on the back of the device.
    • Slide the side panels off the back of the mouse.
  3. Razer Ouroboros Lock Switch Replacement: paso 3, imagen 1 de 2 Razer Ouroboros Lock Switch Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Using your tweezers, grab the trigger switch that you want to replace, and lift it from its slot.
    • If you have your replacement switch, place it in the newly freed slot and reassemble your device.
    • Note: the top guards of this mouse can come off now that the panel screws have been removed. Make sure these stay in place when reassembling.
Conclusión
Una persona más ha completado esta guía.
Preston Darling
Miembro Desde 07/26/16
372 Reputación
2 Guías creadas
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 22
Todo El Tiempo: 3,549
