Saltar al contenido principal
Razer Naga Trinity LK-E5 Optical Encoder Replacement
Qué necesitas
  1. Razer Naga Trinity LK-E5 Optical Encoder Replacement, Razer Naga Trinity Disassembly: paso 1, imagen 1 de 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement, Razer Naga Trinity Disassembly: paso 1, imagen 2 de 2
    • Remove the interchangeable side plate.
  2. Razer Naga Trinity LK-E5 Optical Encoder Replacement: paso 2, imagen 1 de 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: paso 2, imagen 2 de 2
    • Remove the mouse's feet using the opening pick.
  3. Razer Naga Trinity LK-E5 Optical Encoder Replacement: paso 3, imagen 1 de 1
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
  4. Razer Naga Trinity LK-E5 Optical Encoder Replacement: paso 4, imagen 1 de 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: paso 4, imagen 2 de 2
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
  5. Razer Naga Trinity LK-E5 Optical Encoder Replacement: paso 5, imagen 1 de 1
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
  6. Razer Naga Trinity LK-E5 Optical Encoder Replacement: paso 6, imagen 1 de 1
    • Remove the side housing using the opening pick.
  7. Razer Naga Trinity LK-E5 Optical Encoder Replacement: paso 7, imagen 1 de 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: paso 7, imagen 2 de 2
    • Remove the top housing LED 3-Pin connector that is near the main board.
  8. Razer Naga Trinity LK-E5 Optical Encoder Replacement, Scroll Wheel Housing: paso 8, imagen 1 de 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement, Scroll Wheel Housing: paso 8, imagen 2 de 2
    • Remove one 4mm black Phillips #000 screw from the left side of the mouse holding the scroll wheel LED controller board.
    • Then pull the LED controller board upwards and out.
  9. Razer Naga Trinity LK-E5 Optical Encoder Replacement: paso 9, imagen 1 de 1
    • Pry and remove the scroll wheel feedback bar from its hold-down clips using the hook end of a halberd spudger.
  10. Razer Naga Trinity LK-E5 Optical Encoder Replacement: paso 10, imagen 1 de 1
    • Remove the scroll wheel feedback bar from the scroll wheel by holding down the spring and using angled tweezers to remove it from its placement.
  11. Razer Naga Trinity LK-E5 Optical Encoder Replacement: paso 11, imagen 1 de 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: paso 11, imagen 2 de 2
    • Remove the scroll wheel optical encoder 3-pin connector from the main board by wiggling the connector upwards.
  12. Razer Naga Trinity LK-E5 Optical Encoder Replacement: paso 12, imagen 1 de 3 Razer Naga Trinity LK-E5 Optical Encoder Replacement: paso 12, imagen 2 de 3 Razer Naga Trinity LK-E5 Optical Encoder Replacement: paso 12, imagen 3 de 3
    • Using the opening tool, pry the black bracket holding the scroll wheel in place backwards until the scroll wheel housing pops out.
  13. Razer Naga Trinity LK-E5 Optical Encoder Replacement, LK-E5 Optical Encoder: paso 13, imagen 1 de 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement, LK-E5 Optical Encoder: paso 13, imagen 2 de 2
    • Remove the scroll wheel from the scroll wheel housing using the opening tool.
  14. Razer Naga Trinity LK-E5 Optical Encoder Replacement: paso 14, imagen 1 de 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: paso 14, imagen 2 de 2
    • Remove the scroll wheel optical encoder from the scroll wheel.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Where can we buy a replacement from?
Daniel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 55
Todo El Tiempo: 2,123
