Saltar al contenido principal
Razer Naga Trinity LED Light Ribbon Cable Replacement
Qué necesitas
  1. Razer Naga Trinity LED Light Ribbon Cable Replacement, Razer Naga Trinity Disassembly: paso 1, imagen 1 de 2 Razer Naga Trinity LED Light Ribbon Cable Replacement, Razer Naga Trinity Disassembly: paso 1, imagen 2 de 2
    • Remove the interchangeable side plate.
  2. Razer Naga Trinity LED Light Ribbon Cable Replacement: paso 2, imagen 1 de 2 Razer Naga Trinity LED Light Ribbon Cable Replacement: paso 2, imagen 2 de 2
    • Remove the mouse's feet using the opening pick.
  3. Razer Naga Trinity LED Light Ribbon Cable Replacement: paso 3, imagen 1 de 1
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
  4. Razer Naga Trinity LED Light Ribbon Cable Replacement: paso 4, imagen 1 de 2 Razer Naga Trinity LED Light Ribbon Cable Replacement: paso 4, imagen 2 de 2
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
  5. Razer Naga Trinity LED Light Ribbon Cable Replacement: paso 5, imagen 1 de 1
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
  6. Razer Naga Trinity LED Light Ribbon Cable Replacement: paso 6, imagen 1 de 1
    • Remove the side housing using the opening pick.
  7. Razer Naga Trinity LED Light Ribbon Cable Replacement: paso 7, imagen 1 de 2 Razer Naga Trinity LED Light Ribbon Cable Replacement: paso 7, imagen 2 de 2
    • Remove the top housing LED 3-Pin connector that is near the main board.
  8. Razer Naga Trinity LED Light Ribbon Cable Replacement, LED Light Ribbon Cable: paso 8, imagen 1 de 2 Razer Naga Trinity LED Light Ribbon Cable Replacement, LED Light Ribbon Cable: paso 8, imagen 2 de 2
    • Using the flat end of a spudger, unlock the ribbon cable holding the clips.
    • Remove the ribbon cable.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 24
Todo El Tiempo: 1,517
