Saltar al contenido principal
Razer Naga Expert MMO Top Plastic Shell Replacement
Qué necesitas
  1. Razer Naga Expert MMO Top Plastic Shell Replacement, Top Plastic Shell: paso 1, imagen 1 de 1
    • Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
  2. Razer Naga Expert MMO Top Plastic Shell Replacement: paso 2, imagen 1 de 1
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
  3. Razer Naga Expert MMO Top Plastic Shell Replacement: paso 3, imagen 1 de 1
    • Gently remove the top plastic plate of the mouse.
    • Unplug the white cord from the circuit board.
  4. Razer Naga Expert MMO Top Plastic Shell Replacement: paso 4, imagen 1 de 1
    • Lightly pull the two plastic sides of the mouse to remove them.
Conclusión
5 personas más completaron esta guía.
2 comentarios
do you know where i can get a new top body section? i have a molten that stopped left clicking on every click, i opened it up and the plastic pretty much was worn away
pipsqueak642 - Contestar
i’m after the rubber adhesive for the side of this mouse if any one knows where to buy it from cheers.
mayo22 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 27
Todo El Tiempo: 1,835
