Introducción
Be sure to be to keep track of the different types of screws used and where they go. Also be careful with the new cable being installed, as too much interaction with it could mess up its internal wiring.
Qué necesitas
Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
Using a Phillips #00 screwdriver, remove the 5mm screw holding the scroll wheel in place.
Using a Phillips #00 screwdriver, remove all five 5mm screws that connect the motherboard to the main frame.
Once the motherboard is removed, pull the wire out of the plastic grooves on the bottom shell.
Then to completely detach the cable, unplug its white connection port from the motherboard.
3 personas más completaron esta guía.
