Saltar al contenido principal
Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement
Qué necesitas
  1. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement, Scroll Wheel Encoder: paso 1, imagen 1 de 1
    • Peel back the two teflon pads from the top corners and the one larger one from the bottom with the help of a spudger.
    • You will find four 7 mm screws under the teflon pads.
  2. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: paso 2, imagen 1 de 1
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
  3. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: paso 3, imagen 1 de 2 Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: paso 3, imagen 2 de 2
    • Gently remove the top plastic shell from the mouse.
    • Be careful when lifting the shell up to avoid damage to the cable connected to the board and shell.
    • The top shell is separate from the sides of the mouse.
    • Unplug the cable coming from the top shell that connects to the board.
  4. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: paso 4, imagen 1 de 1
    • Gently pull the two plastic sides off the mouse.
    • Pry the sides off gently so you don't crack any of the plastic tabs that hold them in place.
  5. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: paso 5, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the 5 mm screw holding the scroll wheel in place.
    • This screw is different than the ones at the bottom of the mouse so keep it separate.
  6. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: paso 6, imagen 1 de 1
    • Unplug the cord that connects the scroll wheel to the motherboard.
  7. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: paso 7, imagen 1 de 1
    • Gently slide the lighting chip up and out of the scroll wheel.
  8. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: paso 8, imagen 1 de 1
    • Use a spudger to gently pry the scroll wheel assembly out from the plastic housing.
  9. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: paso 9, imagen 1 de 1
    • Remove the scroll wheel from the holder by pushing it up from underneath.
  10. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: paso 10, imagen 1 de 1
    • Remove the old encoder chip and replace with the new one.
    • Make sure that the silver part of the encoder faces out and that the small square points down when reinstalling.
Conclusión
Tony Di Folca
Miembro Desde 05/13/19
231 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 18
Ultimos 30 días: 59
Todo El Tiempo: 1,403
