Saltar al contenido principal
Razer Huntsman Tournament Edition Port Replacement
Qué necesitas
  1. Razer Huntsman Tournament Edition Port Replacement, Keycaps: paso 1, imagen 1 de 1
    • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
  2. Razer Huntsman Tournament Edition Port Replacement: paso 2, imagen 1 de 2 Razer Huntsman Tournament Edition Port Replacement: paso 2, imagen 2 de 2
    • Grip the keycap with your keycap puller.
    • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
  3. Razer Huntsman Tournament Edition Port Replacement: paso 3, imagen 1 de 3 Razer Huntsman Tournament Edition Port Replacement: paso 3, imagen 2 de 3 Razer Huntsman Tournament Edition Port Replacement: paso 3, imagen 3 de 3
    • Pull with an upwards force to remove the keycap.
    • Take a moment to clean the area that was previously obscured if it’s dirty.
    • Use gentle force so as not to damage the stabilizers.
  4. Razer Huntsman Tournament Edition Port Replacement, Chassis: paso 4, imagen 1 de 1
    • Remove all of the keycaps with a keycap puller.
  5. Razer Huntsman Tournament Edition Port Replacement: paso 5, imagen 1 de 2 Razer Huntsman Tournament Edition Port Replacement: paso 5, imagen 2 de 2
    • Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
  6. Razer Huntsman Tournament Edition Port Replacement: paso 6, imagen 1 de 1
    • Use an opening tool to pry open the chassis.
    • Be careful not to use excessive force during this step so the plastic doesn't warp or break.
  7. Razer Huntsman Tournament Edition Port Replacement: paso 7, imagen 1 de 1
    • Gently lift the front panel off.
    • The front panel should be connected to the USB board. Do not tug the panel off as this may damage other parts.
  8. Razer Huntsman Tournament Edition Port Replacement: paso 8, imagen 1 de 1
    • Disconnect the internal cable.
  9. Razer Huntsman Tournament Edition Port Replacement, Port: paso 9, imagen 1 de 2 Razer Huntsman Tournament Edition Port Replacement, Port: paso 9, imagen 2 de 2
    • Unscrew the board with the port.
    • It should be located on the upper left, held in by two 6.5mm Phillips #0 screws.
    • Move the cable out of the way for the second screw
  10. Razer Huntsman Tournament Edition Port Replacement: paso 10, imagen 1 de 1
    • Detach the internal cable from the USB board.
    • Do this carefully.
  11. Razer Huntsman Tournament Edition Port Replacement: paso 11, imagen 1 de 1
    • Remove the USB board.
Conclusión
Una persona más ha completado esta guía.
Joseph O'Dowd
Miembro Desde 10/25/22
383 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 Miembro de UMass Dartmouth, Team 4-3, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G3
5 Miembros
7 Guías creadas
Un comentario
how do i get a new port and where
Guardian Suit - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 26
Todo El Tiempo: 324
