Saltar al contenido principal
Razer Huntsman Tournament Edition Mainboard Replacement
Qué necesitas
  1. Razer Huntsman Tournament Edition Mainboard Replacement, Keycaps: paso 1, imagen 1 de 1
    • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
  2. Razer Huntsman Tournament Edition Mainboard Replacement: paso 2, imagen 1 de 2 Razer Huntsman Tournament Edition Mainboard Replacement: paso 2, imagen 2 de 2
    • Grip the keycap with your keycap puller.
    • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
  3. Razer Huntsman Tournament Edition Mainboard Replacement: paso 3, imagen 1 de 3 Razer Huntsman Tournament Edition Mainboard Replacement: paso 3, imagen 2 de 3 Razer Huntsman Tournament Edition Mainboard Replacement: paso 3, imagen 3 de 3
    • Pull with an upwards force to remove the keycap.
    • Take a moment to clean the area that was previously obscured if it’s dirty.
    • Use gentle force so as not to damage the stabilizers.
  4. Razer Huntsman Tournament Edition Mainboard Replacement, Chassis: paso 4, imagen 1 de 1
    • Remove all of the keycaps with a keycap puller.
  5. Razer Huntsman Tournament Edition Mainboard Replacement: paso 5, imagen 1 de 2 Razer Huntsman Tournament Edition Mainboard Replacement: paso 5, imagen 2 de 2
    • Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
  6. Razer Huntsman Tournament Edition Mainboard Replacement: paso 6, imagen 1 de 1
    • Use an opening tool to pry open the chassis.
    • Be careful not to use excessive force during this step so the plastic doesn't warp or break.
  7. Razer Huntsman Tournament Edition Mainboard Replacement: paso 7, imagen 1 de 1
    • Gently lift the front panel off.
    • The front panel should be connected to the USB board. Do not tug the panel off as this may damage other parts.
  8. Razer Huntsman Tournament Edition Mainboard Replacement: paso 8, imagen 1 de 1
    • Disconnect the internal cable.
  9. Razer Huntsman Tournament Edition Mainboard Replacement, Key Switch: paso 9, imagen 1 de 2 Razer Huntsman Tournament Edition Mainboard Replacement, Key Switch: paso 9, imagen 2 de 2
    • Gently push the key switch off of the mainboard with your thumb.
  10. Razer Huntsman Tournament Edition Mainboard Replacement, Mainboard: paso 10, imagen 1 de 2 Razer Huntsman Tournament Edition Mainboard Replacement, Mainboard: paso 10, imagen 2 de 2
    • Remove all of the switches.
  11. Razer Huntsman Tournament Edition Mainboard Replacement: paso 11, imagen 1 de 1
    • Replace the motherboard.
    • Do this in a gentle manner
Conclusión
Joseph O'Dowd
Miembro Desde 10/25/22
383 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 Miembro de UMass Dartmouth, Team 4-3, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G3
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 21
Ultimos 30 días: 81
Todo El Tiempo: 2,077
