Saltar al contenido principal
Razer Huntsman Tournament Edition Keycaps Replacement
Qué necesitas
  1. Razer Huntsman Tournament Edition Keycaps Replacement, Keycaps: paso 1, imagen 1 de 1
    • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
  2. Razer Huntsman Tournament Edition Keycaps Replacement: paso 2, imagen 1 de 2 Razer Huntsman Tournament Edition Keycaps Replacement: paso 2, imagen 2 de 2
    • Grip the keycap with your keycap puller.
    • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
  3. Razer Huntsman Tournament Edition Keycaps Replacement: paso 3, imagen 1 de 3 Razer Huntsman Tournament Edition Keycaps Replacement: paso 3, imagen 2 de 3 Razer Huntsman Tournament Edition Keycaps Replacement: paso 3, imagen 3 de 3
    • Pull with an upwards force to remove the keycap.
    • Take a moment to clean the area that was previously obscured if it’s dirty.
    • Use gentle force so as not to damage the stabilizers.
Conclusión
2 personas más completaron esta guía.
Tony Kuang
Miembro Desde 10/25/22
109 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 Miembro de UMass Dartmouth, Team 4-3, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G3
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 38
Todo El Tiempo: 1,142
