Saltar al contenido principal
Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement
Qué necesitas
  1. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement, Mouse Buttons: paso 1, imagen 1 de 2 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement, Mouse Buttons: paso 1, imagen 2 de 2
    • Use a spudger or opening tool to remove the top skates from the mouse.
    • Poke a hole in the middle of the bar code to expose the 3 screws holding the mouse together.
  2. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: paso 2, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove the three 9 mm screws that are holding the mouse together.
  3. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: paso 3, imagen 1 de 3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: paso 3, imagen 2 de 3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: paso 3, imagen 3 de 3
    • Open the mouse, and use the Phillips #1 screwdriver remove the two 11 mm screws that are located on the left side of the motherboard.
    • Also, remove the single 4 mm screw next to the mouse wheel using the Phillips #1 screwdriver.
    • After you remove all three screws the motherboard should be free.
  4. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: paso 4, imagen 1 de 2 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: paso 4, imagen 2 de 2
    • This is the component that we will be replacing and its 3 contact points.
  5. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Desoldering Pump
    $3.99
    Comprar
    • Using your soldering iron and desoldering pump, desolder the 3 contact points that attach to each button as marked.
    • Be careful when using a soldering iron, as it can burn you if not used correctly.
  6. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: paso 6, imagen 1 de 3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: paso 6, imagen 2 de 3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: paso 6, imagen 3 de 3
    • Remove the button that you just desoldered.
    • Then solder the new button back into place. Repeat for both buttons.
  7. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: paso 7, imagen 1 de 3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: paso 7, imagen 2 de 3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: paso 7, imagen 3 de 3
    • Return the motherboard to its original position, and replace the two 11 mm screws and the single 4 mm screw using a Phillips #1 screwdriver.
  8. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: paso 8, imagen 1 de 1
    • Close up the mouse, and replace the three 9 mm using a Phillips #1 screwdriver.
  9. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: paso 9, imagen 1 de 1
    • Finally, replace the skates and you are finished.
Linea de Meta
5 personas más completaron esta guía.
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 60
Ultimos 30 días: 308
Todo El Tiempo: 6,792
