Saltar al contenido principal
Razer Deathadder Elite Scroll Wheel Replacement
Qué necesitas
  1. Razer Deathadder Elite Scroll Wheel Replacement, Scroll Wheel: paso 1, imagen 1 de 2 Razer Deathadder Elite Scroll Wheel Replacement, Scroll Wheel: paso 1, imagen 2 de 2
    • Pry the skate off the two upper screws.
    • Remove the two upper screws using a Phillips #00 screwdriver.
    • Poke a hole with your screwdriver into the product sticker on the bottom of the mouse.
    • Remove the bottom screw using a Phillips #00 screwdriver.
  2. Razer Deathadder Elite Scroll Wheel Replacement: paso 2, imagen 1 de 2 Razer Deathadder Elite Scroll Wheel Replacement: paso 2, imagen 2 de 2
    • Lift up the upper shell of the mouse.
    • Use caution; the shell if still connected to the base.
    • Detach the two wired connectors from the circuit board.
  3. Razer Deathadder Elite Scroll Wheel Replacement: paso 3, imagen 1 de 3 Razer Deathadder Elite Scroll Wheel Replacement: paso 3, imagen 2 de 3 Razer Deathadder Elite Scroll Wheel Replacement: paso 3, imagen 3 de 3
    • Unscrew the scroll wheel LED.
    • Carefully remove the scroll wheel.
  4. Razer Deathadder Elite Scroll Wheel Replacement: paso 4, imagen 1 de 1
    • Insert the replacement wheel into the mouse.
Conclusión
6 personas más completaron esta guía.
Hamilton Liu
Miembro Desde 11/17/22
214 Reputación
1 Guía escrita
Equipo
Un comentario
Hi! What size and manufacturer is the encoder in this mouse?
m2l2kopower - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 62
Ultimos 30 días: 350
Todo El Tiempo: 4,886
