Saltar al contenido principal
Razer DeathAdder Chroma USB Cable Replacement
Qué necesitas
  1. Razer DeathAdder Chroma USB Cable Replacement, Outer Casing: paso 1, imagen 1 de 1
    • Opening the mouse casing will void any warranty that exists for the mouse.
    • Turn the mouse over so the bottom is facing up.
  2. Razer DeathAdder Chroma USB Cable Replacement: paso 2, imagen 1 de 2 Razer DeathAdder Chroma USB Cable Replacement: paso 2, imagen 2 de 2
    • Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
  3. Razer DeathAdder Chroma USB Cable Replacement: paso 3, imagen 1 de 2 Razer DeathAdder Chroma USB Cable Replacement: paso 3, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
  4. Razer DeathAdder Chroma USB Cable Replacement: paso 4, imagen 1 de 1
    • Use your fingers to identify the location of the screw under the bottom label.
  5. Razer DeathAdder Chroma USB Cable Replacement: paso 5, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
    • Clear the label away from around the screw for easier removal.
  6. Razer DeathAdder Chroma USB Cable Replacement: paso 6, imagen 1 de 3 Razer DeathAdder Chroma USB Cable Replacement: paso 6, imagen 2 de 3 Razer DeathAdder Chroma USB Cable Replacement: paso 6, imagen 3 de 3
    • Turn the mouse over so the bottom is facing down.
    • Separate the top casing from the bottom base by pulling the top casing upwards.
    • Separating the casing too quickly could damage the ribbon connector between the motherboard and the LED lights.
  7. Razer DeathAdder Chroma USB Cable Replacement: paso 7, imagen 1 de 2 Razer DeathAdder Chroma USB Cable Replacement: paso 7, imagen 2 de 2
    • Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
    • Pulling too hard could damage the wire connections.
  8. Razer DeathAdder Chroma USB Cable Replacement, Motherboard: paso 8, imagen 1 de 2 Razer DeathAdder Chroma USB Cable Replacement, Motherboard: paso 8, imagen 2 de 2
    • Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
  9. Razer DeathAdder Chroma USB Cable Replacement: paso 9, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove three 5.5 mm screws.
  10. Razer DeathAdder Chroma USB Cable Replacement: paso 10, imagen 1 de 2 Razer DeathAdder Chroma USB Cable Replacement: paso 10, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
  11. Razer DeathAdder Chroma USB Cable Replacement: paso 11, imagen 1 de 1
    • Use a Phillips #000 screwdriver to remove one 5.0 mm screw.
  12. Razer DeathAdder Chroma USB Cable Replacement: paso 12, imagen 1 de 2 Razer DeathAdder Chroma USB Cable Replacement: paso 12, imagen 2 de 2
    • Disconnect the ribbon connector between the motherboard and the optical sensor.
  13. Razer DeathAdder Chroma USB Cable Replacement: paso 13, imagen 1 de 2 Razer DeathAdder Chroma USB Cable Replacement: paso 13, imagen 2 de 2
    • Remove the motherboard by grasping the sides and gently pulling upward.
  14. Razer DeathAdder Chroma USB Cable Replacement, USB Cable: paso 14, imagen 1 de 1
    • Locate the USB cable.
  15. Razer DeathAdder Chroma USB Cable Replacement: paso 15, imagen 1 de 2 Razer DeathAdder Chroma USB Cable Replacement: paso 15, imagen 2 de 2
    • Remove the USB cable by pulling it up and out.
Conclusión
7 personas más completaron esta guía.
Henry Shi
Miembro Desde 03/26/17
221 Reputación
1 Guía escrita
Equipo
Baylor, Team S5-G2, Williams Spring 2017 Miembro de Baylor, Team S5-G2, Williams Spring 2017
BU-WILLIAMS-S17S5G2
3 Miembros
6 Guías creadas
5 comentarios
Thank you! It realy worked. Btw: The cable for the Deathadder 2013 is working for the Chroma and Elite as well. I Just tried it :)
Pokefreeks - Contestar
Thanks for the advice
João Costa Santos -
Great and easy guide thanx alot, saved me a new mouse :)
jesperkb - Contestar
Is there a reliable website where I can get a replacement cable with low delivery time?
Bubbles EXE - Contestar
where can i get the cable from?
Mourya Singham - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 37
Todo El Tiempo: 14,464
