Saltar al contenido principal
Razer Blade Stealth 2017 Fan Replacement
Qué necesitas
  1. Razer Blade Stealth 2017 Fan Replacement, Battery: paso 1, imagen 1 de 2 Razer Blade Stealth 2017 Fan Replacement, Battery: paso 1, imagen 2 de 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Fan Replacement: paso 2, imagen 1 de 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Fan Replacement: paso 3, imagen 1 de 2 Razer Blade Stealth 2017 Fan Replacement: paso 3, imagen 2 de 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Fan Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Fan Replacement: paso 5, imagen 1 de 2 Razer Blade Stealth 2017 Fan Replacement: paso 5, imagen 2 de 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 Fan Replacement, Fan: paso 6, imagen 1 de 2 Razer Blade Stealth 2017 Fan Replacement, Fan: paso 6, imagen 2 de 2
    • Use a plastic spudger to lift the white clasp on the fan connector.
  7. Razer Blade Stealth 2017 Fan Replacement: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Use tweezers to pull the fan cable out of the opened connector terminal.
  8. Razer Blade Stealth 2017 Fan Replacement: paso 8, imagen 1 de 3 Razer Blade Stealth 2017 Fan Replacement: paso 8, imagen 2 de 3 Razer Blade Stealth 2017 Fan Replacement: paso 8, imagen 3 de 3
    • Use tweezers to squeeze the fan's white header.
    • Disconnect the fan connector by sliding it out toward the rear of the chassis.
  9. Razer Blade Stealth 2017 Fan Replacement: paso 9, imagen 1 de 3 Razer Blade Stealth 2017 Fan Replacement: paso 9, imagen 2 de 3 Razer Blade Stealth 2017 Fan Replacement: paso 9, imagen 3 de 3
    • Remove any tape attached to the fans.
    • Use a Phillips #00 screwdriver to remove the six, 3mm screws and the metal bracket around both fans.
  10. Razer Blade Stealth 2017 Fan Replacement: paso 10, imagen 1 de 2 Razer Blade Stealth 2017 Fan Replacement: paso 10, imagen 2 de 2
    • Use a plastic spudger to slide the fans out of the case.
Conclusión
3 personas más completaron esta guía.
Helene Willits
Miembro Desde 10/10/19
776 Reputación
6 Guías creadas
Equipo
Cal Poly, Team S11-G3, Regan Fall 2019 Miembro de Cal Poly, Team S11-G3, Regan Fall 2019
CPSU-REGAN-F19S11G3
Miembros de 4
7 Guías creadas
1Guía Comentario
What is the part number for the black fan? I'm trying to buy a replacement but I can't find any :(
Sang Jae Kouwenberg - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 38
Todo El Tiempo: 2,475
