Saltar al contenido principal
Razer Blade Stealth 2017 Audio and USB-A Port Replacement
Qué necesitas
  1. Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Battery: paso 1, imagen 1 de 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Battery: paso 1, imagen 2 de 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: paso 2, imagen 1 de 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: paso 3, imagen 1 de 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement: paso 3, imagen 2 de 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: paso 5, imagen 1 de 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement: paso 5, imagen 2 de 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Audio and USB-A Port: paso 6, imagen 1 de 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Audio and USB-A Port: paso 6, imagen 2 de 2
    • Use a plastic spudger to lift up the module connector.
  7. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: paso 7, imagen 1 de 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement: paso 7, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the two, 3mm screws from the USB-A and audio port module.
  8. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: paso 8, imagen 1 de 1
    • Use a plastic spudger to remove the USB-A and audio port module from the chassis.
Conclusión
Una persona más ha completado esta guía.
Helene Willits
Miembro Desde 10/10/19
762 Reputación
6 Guías creadas
Equipo
Cal Poly, Team S11-G3, Regan Fall 2019 Miembro de Cal Poly, Team S11-G3, Regan Fall 2019
CPSU-REGAN-F19S11G3
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 1,703
