Saltar al contenido principal
Razer Blade Stealth 2016 Speakers Replacement
Qué necesitas
  1. Razer Blade Stealth 2016 Speakers Replacement, Battery: paso 1, imagen 1 de 3 Razer Blade Stealth 2016 Speakers Replacement, Battery: paso 1, imagen 2 de 3 Razer Blade Stealth 2016 Speakers Replacement, Battery: paso 1, imagen 3 de 3
    • Use a Torx screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 Speakers Replacement: paso 2, imagen 1 de 2 Razer Blade Stealth 2016 Speakers Replacement: paso 2, imagen 2 de 2
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 Speakers Replacement: paso 3, imagen 1 de 1
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 Speakers Replacement, Speakers: paso 4, imagen 1 de 1
    • Remove two 3.4 mm screws from each speaker using a T4 Torx screwdriver.
    • Remove the speakers from the laptop.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 184
