Saltar al contenido principal
Razer Blade Stealth 2016 Motherboard Replacement
Qué necesitas
  1. Razer Blade Stealth 2016 Motherboard Replacement, Battery: paso 1, imagen 1 de 3 Razer Blade Stealth 2016 Motherboard Replacement, Battery: paso 1, imagen 2 de 3 Razer Blade Stealth 2016 Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    • Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 Motherboard Replacement: paso 2, imagen 1 de 2 Razer Blade Stealth 2016 Motherboard Replacement: paso 2, imagen 2 de 2
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 Motherboard Replacement: paso 3, imagen 1 de 1
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 Motherboard Replacement, Motherboard: paso 4, imagen 1 de 1
    • Remove the red and black cables that are attached to the motherboard.
  5. Razer Blade Stealth 2016 Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove the four 3.4 mm screws around the black square using a T4 Torx screwdriver.
    • Remove the heatsink.
  6. Razer Blade Stealth 2016 Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the 3.4 mm screws to the cooling fans using a T4 Torx screwdriver.
    • Remove the cooling fans.
  7. Razer Blade Stealth 2016 Motherboard Replacement: paso 7, imagen 1 de 3 Razer Blade Stealth 2016 Motherboard Replacement: paso 7, imagen 2 de 3 Razer Blade Stealth 2016 Motherboard Replacement: paso 7, imagen 3 de 3
    • Remove the 3.4 mm screws on the perimeter of the motherboard using a T4 Torx screwdriver.
  8. Razer Blade Stealth 2016 Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove the motherboard.
Conclusión
Una persona más ha completado esta guía.
2 comentarios
Hi Sadie. It's complicated for me with the battery disconnector, I can't remove it. would you help me with that?
Matias Urani - Contestar
Hi @matiasurani. It looks like the connector is covered by tape so you might have to remove the tape first. The battery is connected to the motherboard by a press connector. Take a look at this guide for how to disconnect it safely. Thanks!
Sarah Westberg -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 689
