Saltar al contenido principal
Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement
Qué necesitas
  1. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Battery: paso 1, imagen 1 de 3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Battery: paso 1, imagen 2 de 3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Battery: paso 1, imagen 3 de 3
    • Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: paso 2, imagen 1 de 2 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: paso 2, imagen 2 de 2
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: paso 3, imagen 1 de 1
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Killer 1535 Wireless Card: paso 4, imagen 1 de 3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Killer 1535 Wireless Card: paso 4, imagen 2 de 3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Killer 1535 Wireless Card: paso 4, imagen 3 de 3
    • Carefully remove the auxiliary and main wire from the Killer 1535 wireless card.
  5. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: paso 5, imagen 1 de 3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: paso 5, imagen 2 de 3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: paso 5, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the two 2.61 mm screw holding the card in place.
  6. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: paso 6, imagen 1 de 2 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: paso 6, imagen 2 de 2
    • Carefully remove the card.
Conclusión
Kaitlyn Murray
Miembro Desde 10/10/19
239 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S1-G4, Leahy Fall 2019 Miembro de USF Tampa, Team S1-G4, Leahy Fall 2019
USFT-LEAHY-F19S1G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 992
