Saltar al contenido principal
Razer Blade Stealth 2016 Heat Sink Replacement
Qué necesitas
  1. Razer Blade Stealth 2016 Heat Sink Replacement, Battery: paso 1, imagen 1 de 3 Razer Blade Stealth 2016 Heat Sink Replacement, Battery: paso 1, imagen 2 de 3 Razer Blade Stealth 2016 Heat Sink Replacement, Battery: paso 1, imagen 3 de 3
    • Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 Heat Sink Replacement: paso 2, imagen 1 de 2 Razer Blade Stealth 2016 Heat Sink Replacement: paso 2, imagen 2 de 2
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 Heat Sink Replacement: paso 3, imagen 1 de 1
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 Heat Sink Replacement, Fans: paso 4, imagen 1 de 2 Razer Blade Stealth 2016 Heat Sink Replacement, Fans: paso 4, imagen 2 de 2
    • Remove the three 3.38 mm screws from the left fan (this fan should be black).
  5. Razer Blade Stealth 2016 Heat Sink Replacement: paso 5, imagen 1 de 1
    • Carefully lift and remove the left fan.
  6. Razer Blade Stealth 2016 Heat Sink Replacement: paso 6, imagen 1 de 3 Razer Blade Stealth 2016 Heat Sink Replacement: paso 6, imagen 2 de 3 Razer Blade Stealth 2016 Heat Sink Replacement: paso 6, imagen 3 de 3
    • Repeat steps five and six to remove the silver, right fan.
  7. Razer Blade Stealth 2016 Heat Sink Replacement, Heat Sink: paso 7, imagen 1 de 2 Razer Blade Stealth 2016 Heat Sink Replacement, Heat Sink: paso 7, imagen 2 de 2
    • Remove the four 3.38 mm screws around the black square using a Phillips #00 screwdriver.
  8. Razer Blade Stealth 2016 Heat Sink Replacement: paso 8, imagen 1 de 3 Razer Blade Stealth 2016 Heat Sink Replacement: paso 8, imagen 2 de 3 Razer Blade Stealth 2016 Heat Sink Replacement: paso 8, imagen 3 de 3
    • Once the screws are removed, the piece can be gently lifted from the back of the device.
Conclusión
Una persona más ha completado esta guía.
Lindsay Grant
Miembro Desde 10/10/19
403 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S1-G4, Leahy Fall 2019 Miembro de USF Tampa, Team S1-G4, Leahy Fall 2019
USFT-LEAHY-F19S1G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 1,347
