Saltar al contenido principal
Razer Blade Stealth 2017 Battery Replacement
Qué necesitas
  1. Razer Blade Stealth 2017 Battery Replacement, Battery: paso 1, imagen 1 de 2 Razer Blade Stealth 2017 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Battery Replacement: paso 2, imagen 1 de 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Battery Replacement: paso 3, imagen 1 de 2 Razer Blade Stealth 2017 Battery Replacement: paso 3, imagen 2 de 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Battery Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Battery Replacement: paso 5, imagen 1 de 2 Razer Blade Stealth 2017 Battery Replacement: paso 5, imagen 2 de 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
14 personas más completaron esta guía.
Equipo
Cal Poly, Team S11-G3, Regan Fall 2019 Miembro de Cal Poly, Team S11-G3, Regan Fall 2019
CPSU-REGAN-F19S11G3
4 Miembros
7 Guías creadas
Un comentario
ive done everything correctly and laptop boots up but now I have no battery percentage information. any solutions on how to fix?
fdf - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 21
Ultimos 30 días: 142
Todo El Tiempo: 16,465
