Saltar al contenido principal
Razer Blade RZ09-0130 2015 Trackpad Button Replacement
Qué necesitas
  1. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Back Panel: paso 1, imagen 1 de 2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Back Panel: paso 1, imagen 2 de 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: paso 2, imagen 1 de 2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement: paso 2, imagen 2 de 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: paso 3, imagen 1 de 3 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: paso 3, imagen 2 de 3 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: paso 3, imagen 3 de 3
    • Detach the two connectors from the motherboard by gently pulling them directly out of their ports with your fingers.
  4. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: paso 4, imagen 1 de 2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement: paso 4, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws holding the trackpad's circuit board to the chassis.
  5. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: paso 5, imagen 1 de 1
    • Remove the trackpad circuit board by holding one end and gently lifting it upwards.
Conclusión
Equipo
Cal Poly, Team S18-G1, White Winter 2020 Miembro de Cal Poly, Team S18-G1, White Winter 2020
CPSU-WHITE-W20S18G1
4 Miembros
6 Guías creadas
Un comentario
Looking for that small ribbon cable, very hard to find, any clues?
serpentexotics - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 21
Todo El Tiempo: 2,167
