Saltar al contenido principal
Razer Blade RZ09-0130 2015 Speaker Replacement
Qué necesitas
  1. Razer Blade RZ09-0130 2015 Speaker Replacement, Back Panel: paso 1, imagen 1 de 2 Razer Blade RZ09-0130 2015 Speaker Replacement, Back Panel: paso 1, imagen 2 de 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Speaker Replacement: paso 2, imagen 1 de 2 Razer Blade RZ09-0130 2015 Speaker Replacement: paso 2, imagen 2 de 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Speaker Replacement, Speaker: paso 3, imagen 1 de 1
    • Using the Phillips #0 screwdriver, remove the two 3mm screws from the right speaker.
  4. Razer Blade RZ09-0130 2015 Speaker Replacement: paso 4, imagen 1 de 2 Razer Blade RZ09-0130 2015 Speaker Replacement: paso 4, imagen 2 de 2
    • Using your fingers, gently pull on the wire connecting the speaker to the motherboard until it disconnects.
  5. Razer Blade RZ09-0130 2015 Speaker Replacement: paso 5, imagen 1 de 1
    • Pick up and remove the speaker.
  6. Razer Blade RZ09-0130 2015 Speaker Replacement: paso 6, imagen 1 de 1
    • Repeat the preceding steps to remove the second speaker.
Conclusión
Equipo
Cal Poly, Team S18-G1, White Winter 2020 Miembro de Cal Poly, Team S18-G1, White Winter 2020
CPSU-WHITE-W20S18G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 13
Todo El Tiempo: 342
