Introducción
If yourRazer Blade RZ09-0130 2015 isn’t starting or its performance is lackluster, your motherboard may be damaged. Because the motherboard is the most essential component to a computer, proceed with extra caution when going through these instructions. Although other components may work as expected, they could become damaged if the motherboard is mishandled.
Qué necesitas
Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
Using the Phillips #0 screwdriver, remove the two 3mm screws from the right speaker.
Using the Phillips #0 screwdriver, remove the four 3mm screws connecting the motherboard to the chassis of the device.
