Saltar al contenido principal
Razer Blade RZ09-0130 2015 Fan Replacement
Qué necesitas
  1. Razer Blade RZ09-0130 2015 Fan Replacement, Back Panel: paso 1, imagen 1 de 2 Razer Blade RZ09-0130 2015 Fan Replacement, Back Panel: paso 1, imagen 2 de 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Fan Replacement: paso 2, imagen 1 de 2 Razer Blade RZ09-0130 2015 Fan Replacement: paso 2, imagen 2 de 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Fan Replacement, Fan: paso 3, imagen 1 de 2 Razer Blade RZ09-0130 2015 Fan Replacement, Fan: paso 3, imagen 2 de 2
    • Remove the three screw caps by pulling them upward with your fingers.
  4. Razer Blade RZ09-0130 2015 Fan Replacement: paso 4, imagen 1 de 1
    • Remove the three 3mm Phillips #0 screws.
  5. Razer Blade RZ09-0130 2015 Fan Replacement: paso 5, imagen 1 de 2 Razer Blade RZ09-0130 2015 Fan Replacement: paso 5, imagen 2 de 2
    • Peel back the two adhesive strips from the fan until they are removed.
  6. Razer Blade RZ09-0130 2015 Fan Replacement: paso 6, imagen 1 de 3 Razer Blade RZ09-0130 2015 Fan Replacement: paso 6, imagen 2 de 3 Razer Blade RZ09-0130 2015 Fan Replacement: paso 6, imagen 3 de 3
    • Remove the connector by pulling it away from the motherboard with your fingers.
  7. Razer Blade RZ09-0130 2015 Fan Replacement: paso 7, imagen 1 de 1
    • Holding the rounded edge of the fan, slowly lift upwards until it is removed.
  8. Razer Blade RZ09-0130 2015 Fan Replacement: paso 8, imagen 1 de 1
    • Repeat the preceding steps to remove the second fan.
Conclusión
Tyler Clayton
Miembro Desde 01/22/20
183 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S18-G1, White Winter 2020 Miembro de Cal Poly, Team S18-G1, White Winter 2020
CPSU-WHITE-W20S18G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 608
