Saltar al contenido principal
Razer Blade RZ09-0102 Speakers Replacement
Qué necesitas
  1. Razer Blade RZ09-0102 Speakers Replacement, Rear Panel: paso 1, imagen 1 de 1
    • Before you begin, be sure to turn off your laptop.
    • Using a Torx T5 screwdriver, remove the ten 1/8 inch screws securing the back cover.
    • Remove the back cover.
  2. Razer Blade RZ09-0102 Speakers Replacement, Speakers: paso 2, imagen 1 de 2 Razer Blade RZ09-0102 Speakers Replacement, Speakers: paso 2, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove the two screws holding down the speaker.
  3. Razer Blade RZ09-0102 Speakers Replacement: paso 3, imagen 1 de 1
    • Disconnect the wire by pinching with your fingers and pulling up.
  4. Razer Blade RZ09-0102 Speakers Replacement: paso 4, imagen 1 de 1
    • Remove the speaker.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 1,005
