Saltar al contenido principal
Razer Blackwidow Ultimate 2013 Key Replacement
Qué necesitas
  1. Razer Blackwidow Ultimate 2013 Key Replacement, Key: paso 1, imagen 1 de 2 Razer Blackwidow Ultimate 2013 Key Replacement, Key: paso 1, imagen 2 de 2
    • The regular size keys only require your fingers to remove them, so gently pull them off the keyboard.
  2. Razer Blackwidow Ultimate 2013 Key Replacement: paso 2, imagen 1 de 2 Razer Blackwidow Ultimate 2013 Key Replacement: paso 2, imagen 2 de 2
    • For larger keys, such as the space bar or shift keys, the axel underneath needs to be released by gently pulling it out and away from the center of the keyboard with the metal spudger.
  3. Razer Blackwidow Ultimate 2013 Key Replacement: paso 3, imagen 1 de 1
    • Ensure the keys are in alignment with the groves on the keyboard. Press the keys into the keyboard to lock them in place. Do not apply too much force while pressing the keys into the keyboard.
Conclusión
3 personas más completaron esta guía.
Jacob Scoles
Miembro Desde 09/17/15
549 Reputación
2 Guías creadas
Equipo
IUPUI, Team 2-3, Harley Fall 2015 Miembro de IUPUI, Team 2-3, Harley Fall 2015
IUPUI-HARLEY-F15S2G3
4 Miembros
4 Guías creadas
2 comentarios
How can I buy the keys?
MRcrem RS - Contestar
You described how to remove a key cover. You did not describe how to remove a key switch and whether or not replacement switches may be purchased.
Steven Oliger - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 82
Todo El Tiempo: 7,868
