Saltar al contenido principal
Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement
Qué necesitas
  1. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement, USB Port Board: paso 1, imagen 1 de 3 Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement, USB Port Board: paso 1, imagen 2 de 3 Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement, USB Port Board: paso 1, imagen 3 de 3
    • Remove the four plastic covers and rubber feet from all four corners of the keyboard.
    • Remove the four screws.
    • Carefully pry around the bottom end of the keyboard and work your way around keyboard to un-clip the face.
  2. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: paso 2, imagen 1 de 2 Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: paso 2, imagen 2 de 2
    • Turn the keyboard face up.
    • Remove the four screws which attach the keys.
    • Note the orientation of the white plastic cover relative to the LED at the bottom of the board.
  3. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: paso 3, imagen 1 de 1
    • Locate the USB at the top of the device.
    • Remove the two screws attaching the USB.
  4. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: paso 4, imagen 1 de 2 Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: paso 4, imagen 2 de 2
    • Unplug the cable connecting to the USB board.
    • Plug the new USB board into the slot.
    • Replace the screws in the USB board.
Conclusión
Una persona más ha completado esta guía.
4 comentarios
hi, where do i get the new board from? thanks!
Doge The Best - Contestar
You can easily find it on Ebay
Here's a link, i had the same issue
https://www.ebay.com/itm/272275162673htt...
iixroyal owlroyal -
Hey, you can easily Google the details on the USB board bottom left
I had the same issue
iixroyal owlroyal - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 31
Todo El Tiempo: 5,038
