Saltar al contenido principal
Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement
Qué necesitas
  1. Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement, Metal Bar on Keys: paso 1, imagen 1 de 1
    • Before you do anything, take a picture of the entire keyboard so as to know where the keys go at the end.
    • Gently start to remove the keys surrounding the keys with the bars in them.
  2. Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement: paso 2, imagen 1 de 3 Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement: paso 2, imagen 2 de 3 Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement: paso 2, imagen 3 de 3
    • Move the key itself off of one side of the bar from where it connects to easily allow the other side to be removed as well.
    • Another way to do it is to push the bar itself out gently with the metal spudger.
  3. Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement: paso 3, imagen 1 de 2 Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement: paso 3, imagen 2 de 2
    • Gently pop the bar out from its sockets.
    • Pop the new bar back into the sockets.
  4. Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement: paso 4, imagen 1 de 1
    • Gently slide one side of the key into the bar and then use the metal spudger to pop the other side into place.
    • Use the picture from the beginning if necessary to make sure all the keys are in the right place.
Conclusión
Un comentario
I bought my keyboard second hand have I either gotten a different keyboard or have the lad's been removed or is it a different model as I still have the Fn key which usually turns them on.
BettyBulldog123 a.k.a Betty - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 11
Ultimos 30 días: 36
Todo El Tiempo: 4,168
