Saltar al contenido principal
Razer BlackWidow Chroma Key Replacement
Qué necesitas
  1. Razer BlackWidow Chroma Key Replacement, Key: paso 1, imagen 1 de 1
    • If the problematic key is still attached, place the edge of the medium blue pry tool under the key. Then gently pry up until key is detached.
  2. Razer BlackWidow Chroma Key Replacement: paso 2, imagen 1 de 1
    • Some larger keys may also be held in by two small metal hooks. To separate them gently slide the key left to separate right hook, then to the right to separate the left hook. Be careful not to break the mounting holes on the key itself.
Conclusión
7 personas más completaron esta guía.
Kirk Foreman
Miembro Desde 02/01/17
248 Reputación
1 Guía escrita
Equipo
UW Tacoma, Team 2-6, Rose Winter 2017 Miembro de UW Tacoma, Team 2-6, Rose Winter 2017
UWT-ROSE-W17S2G6
3 Miembros
3 Guías creadas
3 comentarios
This has absolutely nothing to do with fixing a stuck key. Useless information.
Kyle - Contestar
99% of steps to replace a key is missing. What a joke.
Jacinto - Contestar
please change the name to “keycap” I don’t see this as useless but, misleading.
Shaun Conklin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 25
Ultimos 30 días: 83
Todo El Tiempo: 12,149
