Saltar al contenido principal
Razer BlackWidow Chroma Back Panel Replacement
Qué necesitas
  1. Razer BlackWidow Chroma Back Panel Replacement, Rubber Feet: paso 1, imagen 1 de 2 Razer BlackWidow Chroma Back Panel Replacement, Rubber Feet: paso 1, imagen 2 de 2
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer BlackWidow Chroma Back Panel Replacement, Front Panel: paso 2, imagen 1 de 2 Razer BlackWidow Chroma Back Panel Replacement, Front Panel: paso 2, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
  3. Razer BlackWidow Chroma Back Panel Replacement, Back Panel: paso 3, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove all ten screws found along the outer edges of the keyboard.
  4. Razer BlackWidow Chroma Back Panel Replacement: paso 4, imagen 1 de 1
    • Insert the Jimmy along the edges of the back panel and remove the back panel from the device.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Lacks details on where the clips are. It resulted in prying an area where there was one and it broke. We need updated images with those details. If I can I will do do when I reassemble.
Kellic Normand - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 19
Ultimos 30 días: 100
Todo El Tiempo: 4,386
