Introducción
If you've spent enough time exploring the wonderful uses of a Raspberry Pi (Model B Revision 2.0), then you may have explored enough to discover a faulty/broken USB port. No worries; a USB port replacement is an easy fix. First, you are going to need an adequate workspace and some knowledge of soldering/desoldering. Nothing fancy, just a well-ventilated space with clean, stable surfaces. If you do not already own a soldering iron, a fine-tipped model is recommended. Careful, the iron will be very hot; always make sure the iron cord is not in the way of your work.
If you decide to work outside, position yourself away from the wind; the fumes will remain out of your way. Also if you wear contact lenses you must remove them before soldering. If any fumes or debris were to intermingle with the lenses, they might get lodged and be difficult to remove.
Lastly, be patient. The estimated time is only a reference. If you have little or no experience with soldering, it might take some time to develop a rhythm. Also, if you find a technique that works for you, carry on. This is a learning experience, and a perfect port to practice on!
Caution: Soldering/desoldering presents a potential for device damage and burns. Always work in a well-ventilated area.
Qué necesitas
Clean your work area with a lint-resistant wipe.
Make a wire loop out of the desoldering braid to "soak up" the solder on the smaller pins. Hook the pin and place the soldering iron tip on the loop and pin simultaneously.
Use the desoldering braid to “soak up" the melted solder. If the braid will not catch more solder, cut off the end and continue to the smaller pins.
Melt a few millimeters of lead-free solder on the tip of the iron.
Bring the soldering iron with the melted solder close to the pin and its respective base. Slowly apply solder to a combination of the pin, pin-base, and the iron tip until the solder collects into a “bubble,” encapsulating the pin and base.
Your new USB port should be fully functional!
4 personas más completaron esta guía.
