Saltar al contenido principal
Ramos X10 Pro Micro SD Card Replacement
Qué necesitas
  1. Ramos X10 Pro Micro SD Card Replacement, Micro SD Card: paso 1, imagen 1 de 1
    • To uninstall the Micro SD Card, push it in using the plastic opening tools until the Micro SD card clicks. After it clicks, release it and the Micro SD card will stick out of its port.
  2. Ramos X10 Pro Micro SD Card Replacement: paso 2, imagen 1 de 2 Ramos X10 Pro Micro SD Card Replacement: paso 2, imagen 2 de 2
    • Once the Micro SD card is sticking out, pull it out using your fingers.
Conclusión
To reinstall the Micro SD card, follow these instructions in reverse order.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 186
