Saltar al contenido principal
Rain-X Chipped Windshield Repair
Qué necesitas
  1. Rain-X Chipped Windshield Repair, Rain-X Chipped Windshield Repair: paso 1, imagen 1 de 3 Rain-X Chipped Windshield Repair, Rain-X Chipped Windshield Repair: paso 1, imagen 2 de 3 Rain-X Chipped Windshield Repair, Rain-X Chipped Windshield Repair: paso 1, imagen 3 de 3
    • To remove excess glass, scrape over the surface of the chip with the included razor blade.
  2. Rain-X Chipped Windshield Repair: paso 2, imagen 1 de 2 Rain-X Chipped Windshield Repair: paso 2, imagen 2 de 2
    • Attach the Rain-X applicator base to the windshield, with the center of the base directly above the chip.
  3. Rain-X Chipped Windshield Repair: paso 3, imagen 1 de 2 Rain-X Chipped Windshield Repair: paso 3, imagen 2 de 2
    • Cut the tip of the repair resin bottle using the razor blade.
  4. Rain-X Chipped Windshield Repair: paso 4, imagen 1 de 3 Rain-X Chipped Windshield Repair: paso 4, imagen 2 de 3 Rain-X Chipped Windshield Repair: paso 4, imagen 3 de 3
    • To attach resin chamber, screw the chamber into the center ring of the applicator base.
  5. Rain-X Chipped Windshield Repair: paso 5, imagen 1 de 1
    • Screw the resin chamber clockwise until it is in contact with the windshield.
  6. Rain-X Chipped Windshield Repair: paso 6, imagen 1 de 3 Rain-X Chipped Windshield Repair: paso 6, imagen 2 de 3 Rain-X Chipped Windshield Repair: paso 6, imagen 3 de 3
    • Apply 3-6 drops of resin from the resin repair bottle into the resin chamber.
  7. Rain-X Chipped Windshield Repair: paso 7, imagen 1 de 3 Rain-X Chipped Windshield Repair: paso 7, imagen 2 de 3 Rain-X Chipped Windshield Repair: paso 7, imagen 3 de 3
    • To add the pressure driver, screw the driver clockwise into the resin chamber.
    • Make sure to tighten almost all the way.
    • Make sure the pressure driver is in contact with the windshield.
  8. Rain-X Chipped Windshield Repair: paso 8, imagen 1 de 1
    • Set timer for 4-6 minutes - Let the adhesive absorb into the chip for 4-6 minutes.
    • To determine if the repair resin has absorbed properly, look at the glass from a 45 degree angle.
    • After the 4-6 minutes end, unscrew the pressure driver, turning it counter clockwise. Remove it to release any trapped air.
  9. Rain-X Chipped Windshield Repair: paso 9, imagen 1 de 2 Rain-X Chipped Windshield Repair: paso 9, imagen 2 de 2
    • Reinsert pressure driver by twisting clockwise.
    • This will discard any air remaining in the chip.
  10. Rain-X Chipped Windshield Repair: paso 10, imagen 1 de 1
    • To check for remaining damage, look for a dark color to appear.
  11. Rain-X Chipped Windshield Repair: paso 11, imagen 1 de 1
    • Leave to cure for 5-10 minutes.
  12. Rain-X Chipped Windshield Repair: paso 12, imagen 1 de 2 Rain-X Chipped Windshield Repair: paso 12, imagen 2 de 2
    • Once finished curing, remove the resin chamber and the pressure driver by screwing counter clockwise.
  13. Rain-X Chipped Windshield Repair: paso 13, imagen 1 de 2 Rain-X Chipped Windshield Repair: paso 13, imagen 2 de 2
    • Remove the applicator by using the tabs on the suction cups.
  14. Rain-X Chipped Windshield Repair: paso 14, imagen 1 de 2 Rain-X Chipped Windshield Repair: paso 14, imagen 2 de 2
    • Clean off any excess adhesive from the windshield.
  15. Rain-X Chipped Windshield Repair: paso 15, imagen 1 de 2 Rain-X Chipped Windshield Repair: paso 15, imagen 2 de 2
    • Cover the chip gently with a curing strip.
  16. Rain-X Chipped Windshield Repair: paso 16, imagen 1 de 1
    • Move the car into direct sunlight and leave for 4-6 hours.
    • Remove the curing strip and enjoy.
Conclusión
2 personas más completaron esta guía.
Equipo
UC Davis, Team S1-G8, Bender Fall 2018 Miembro de UC Davis, Team S1-G8, Bender Fall 2018
UCD-BENDER-F18S1G8
3 Miembros
1 Guía escrita
Un comentario
If you do not have a sunny day, what is the best UV wavelength in nm, watts, and length of time to fully cure the resin.
Thanks much!
AZRic - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 10
Ultimos 30 días: 55
Todo El Tiempo: 4,635
