Introducción
This guide demonstrates replacing a GPU fan in a Radeon RX 580 graphics card. If you begin to notice one of the fans has stopped functioning completely, then this is an essential repair to complete. Get ready to use a small amount of physical force for some parts of this guide.
Qué necesitas
Lay down the case so that the power button is on the far top right corner and is facing your right.
Remove the top panel by pushing its ridgeline away from you and sliding it off of the case.
Remove the side panel facing you by pushing its ridgeline away from you and lifting it off of the case.
To disconnect the GPU cable, use your thumb and index finger to unlatch the hooking device and pull the cable away.
Gently and carefully press down on the release mechanism on the PCIE slot of the graphics card.
Remove the graphics card from the motherboard by applying back pressure to the card.
Remove the six 1.8 mm screws holding both fans in place by using a Phillips #1 screwdriver in-between the fan blades as the screws are located behind the fans.
Remove the fans by applying back pressure.
Unplug the individual fans from the graphics card.
Una persona más ha completado esta guía.
3 comentarios
This tutorial is not complete, some extra steps are required to unplug the fans power connector.
Indeed, it’s necessary to remove the plastic support above the heat sink (where fans are screwed on) to be able to unplug the fans power connector.
First, the fan support should be removed and the connector should be unplugged before unscrewing the fans from the plastic support.
I have a Gigabyte rx580 ,, is this card easier to unplug than your example .. looks awkward to get to the plug
