Qué necesitas
To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
Fully press the spindle lock button.
With the spindle lock button held down, use the wrench provided to loosen the clamp nut. Once loose, you can use your fingers to unscrew the nut completely
