Saltar al contenido principal
RYOBI P422 Safety Trigger Spring Replacement
Qué necesitas
  1. RYOBI P422 Safety Trigger Spring Replacement, Battery and Handle: paso 1, imagen 1 de 2 RYOBI P422 Safety Trigger Spring Replacement, Battery and Handle: paso 1, imagen 2 de 2
    • To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
    • To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
  2. RYOBI P422 Safety Trigger Spring Replacement, Safety Trigger Spring: paso 2, imagen 1 de 1
    • Lay grinder flat on its side so the screws are facing up
  3. RYOBI P422 Safety Trigger Spring Replacement: paso 3, imagen 1 de 3 RYOBI P422 Safety Trigger Spring Replacement: paso 3, imagen 2 de 3 RYOBI P422 Safety Trigger Spring Replacement: paso 3, imagen 3 de 3
    • Remove the four 1.8 cm screws from the lower and midsection of the body with a T20-20 Torque screwdriver.
    • Remove the 3.7 cm screws from the upper section of the body, with the same screwdriver
  4. RYOBI P422 Safety Trigger Spring Replacement: paso 4, imagen 1 de 3 RYOBI P422 Safety Trigger Spring Replacement: paso 4, imagen 2 de 3 RYOBI P422 Safety Trigger Spring Replacement: paso 4, imagen 3 de 3
    • Now that the two halves are unscrewed, remove the top half
  5. RYOBI P422 Safety Trigger Spring Replacement: paso 5, imagen 1 de 3 RYOBI P422 Safety Trigger Spring Replacement: paso 5, imagen 2 de 3 RYOBI P422 Safety Trigger Spring Replacement: paso 5, imagen 3 de 3
    • Remove the safety trigger along with the spring.
    • To remove the spring, pull it gently off the bottom of the trigger.
    • When putting a new spring in make sure it slides into the grove on the bottom of the trigger.
Conclusión
Thomas Napert
Miembro Desde 03/16/15
279 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 1,494
