Saltar al contenido principal
RYOBI P422 Body Replacement
Qué necesitas
  1. RYOBI P422 Body Replacement, Battery and Handle: paso 1, imagen 1 de 2 RYOBI P422 Body Replacement, Battery and Handle: paso 1, imagen 2 de 2
    • To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
    • To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
  2. RYOBI P422 Body Replacement, Body: paso 2, imagen 1 de 1
    • Lay the grinder flat on its side so the screws are facing up.
  3. RYOBI P422 Body Replacement: paso 3, imagen 1 de 3 RYOBI P422 Body Replacement: paso 3, imagen 2 de 3 RYOBI P422 Body Replacement: paso 3, imagen 3 de 3
    • Remove the four 1.8 cm screws from the lower and mid section of the body with the Torx T20 screwdriver.
    • Remove the 3.7 cm screws from the upper section of the body, with the same screwdriver.
  4. RYOBI P422 Body Replacement: paso 4, imagen 1 de 2 RYOBI P422 Body Replacement: paso 4, imagen 2 de 2
    • Now that the two halves are unscrewed, lift up the top half.
  5. RYOBI P422 Body Replacement: paso 5, imagen 1 de 3 RYOBI P422 Body Replacement: paso 5, imagen 2 de 3 RYOBI P422 Body Replacement: paso 5, imagen 3 de 3
    • Remove the safety trigger and the spring.
    • Be careful in removing the safety trigger, the pin may fall out as you are moving it.
  6. RYOBI P422 Body Replacement: paso 6, imagen 1 de 2 RYOBI P422 Body Replacement: paso 6, imagen 2 de 2
    • Lift up main trigger and spring together.
    • By lifting this trigger and spring out of the handle, you will pull double duty by lifting the black switch box off of its two support posts.
    • Slide the trigger off of the black switch box.
    • Be careful when removing trigger, the spring will be compressed and may move unexpectedly.
  7. RYOBI P422 Body Replacement: paso 7, imagen 1 de 3 RYOBI P422 Body Replacement: paso 7, imagen 2 de 3 RYOBI P422 Body Replacement: paso 7, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Lift the battery lead bracket from its slot.
    • Use the PH 1 screwdriver to unscrew the two 0.7 cm screws that hold the 2.6 cm long brass bracket in place.
    • Use tweezers to remove the brass bracket.
    • During reassembly, remember to keep the spring inside the main trigger and against the bracket that is visible in the second of the accompanying photos.
  8. RYOBI P422 Body Replacement: paso 8, imagen 1 de 2 RYOBI P422 Body Replacement: paso 8, imagen 2 de 2
    • Flip the grinder over and lift off the second half of the body.
    • Now you can replace your damaged handles with a new pair.
Conclusión
2 personas más completaron esta guía.
John Lamanuzzi
Miembro Desde 03/20/15
229 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 1,384
