Saltar al contenido principal
RYDIS H68 Pro Side Brush Motor Replacement
Qué necesitas
  1. RYDIS H68 Pro Side Brush Motor Replacement, Battery: paso 1, imagen 1 de 2 RYDIS H68 Pro Side Brush Motor Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the vacuum over so that the wheels are facing you.
    • Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
  2. RYDIS H68 Pro Side Brush Motor Replacement: paso 2, imagen 1 de 1
    • Lift the battery cover up to reveal the battery.
    • Remove the battery.
  3. RYDIS H68 Pro Side Brush Motor Replacement, Bumper: paso 3, imagen 1 de 3 RYDIS H68 Pro Side Brush Motor Replacement, Bumper: paso 3, imagen 2 de 3 RYDIS H68 Pro Side Brush Motor Replacement, Bumper: paso 3, imagen 3 de 3
    • Remove the eight 10 mm Phillips #1 screws.
  4. RYDIS H68 Pro Side Brush Motor Replacement: paso 4, imagen 1 de 3 RYDIS H68 Pro Side Brush Motor Replacement: paso 4, imagen 2 de 3 RYDIS H68 Pro Side Brush Motor Replacement: paso 4, imagen 3 de 3
    • Hold the front bumper and pull it off.
    • It requires a lot of force to pull the bumper off.
  5. RYDIS H68 Pro Side Brush Motor Replacement: paso 5, imagen 1 de 3 RYDIS H68 Pro Side Brush Motor Replacement: paso 5, imagen 2 de 3 RYDIS H68 Pro Side Brush Motor Replacement: paso 5, imagen 3 de 3
    • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
  6. RYDIS H68 Pro Side Brush Motor Replacement, Side Brush Motor: paso 6, imagen 1 de 1
    • Begin by unscrewing the 2 10mm screws using a Phillips #1 screwdriver.
    • Unlatch the latches indicated. It can be easily done with your finger.
    • Once unsecured, the covering for the sensors can easily be removed allowing access to the sensors.
    • The reason for these first few steps is to avoid damaging the signal wires for the sensor.
  7. RYDIS H68 Pro Side Brush Motor Replacement: paso 7, imagen 1 de 1
    • This step just shows you how everything looks after the previous steps were completed.
    • There are sensors on both the left and right side. This can be done for either side.
  8. RYDIS H68 Pro Side Brush Motor Replacement: paso 8, imagen 1 de 1
    • Unscrew the five 10mm screws using a Phillips #1 screwdriver.
  9. RYDIS H68 Pro Side Brush Motor Replacement: paso 9, imagen 1 de 1
    • The side brush motor can now be removed by lifting it up.
Conclusión
Una persona más ha completado esta guía.
jude auguste
Miembro Desde 02/15/17
108 Reputación
1 Guía escrita
Equipo
USFT-Lacy-S17S005G2 Miembro de USFT-Lacy-S17S005G2
Repair Café
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 584
