Saltar al contenido principal
ROG Strix G16 (G614J) M.2 SSD Replacement
Qué necesitas
  1. ROG Strix G16 (G614J) M.2 SSD Replacement, Remote the Backplate Screws: paso 1, imagen 1 de 2 ROG Strix G16 (G614J) M.2 SSD Replacement, Remote the Backplate Screws: paso 1, imagen 2 de 2
    • Remove the following screws
    • PH0 Screws
    • This one remains captive to the backplate and will not come off.
    • These ones are also PH0 but are longer then the other ones.
  2. ROG Strix G16 (G614J) M.2 SSD Replacement, Opening: paso 2, imagen 1 de 2 ROG Strix G16 (G614J) M.2 SSD Replacement, Opening: paso 2, imagen 2 de 2
    • Slide an Opening Pick around the edge until you make an opening
    • Carfully lift the backplate with your hand
  3. ROG Strix G16 (G614J) M.2 SSD Replacement, Locating Slots: paso 3, imagen 1 de 1
    • There are 2 slots labeled "SSD1" and "SSD2"
    • The SSD1 slot has a preinstalled SSD by the OEM and has your operating system on it
    • The SSD2 slot is free and you can install a M-Key M.2
  4. ROG Strix G16 (G614J) M.2 SSD Replacement, Removing tape: paso 4, imagen 1 de 2 ROG Strix G16 (G614J) M.2 SSD Replacement, Removing tape: paso 4, imagen 2 de 2
    • Lift/Remove the tape to reveal the slot
    • You may decide if you would like to keep the tape, we will be reapplying it in step 9
  5. ROG Strix G16 (G614J) M.2 SSD Replacement, M.2 Screw: paso 5, imagen 1 de 1
    • Remove the PH00 Screw.
  6. ROG Strix G16 (G614J) M.2 SSD Replacement, Inserting the M.2: paso 6, imagen 1 de 3 ROG Strix G16 (G614J) M.2 SSD Replacement, Inserting the M.2: paso 6, imagen 2 de 3 ROG Strix G16 (G614J) M.2 SSD Replacement, Inserting the M.2: paso 6, imagen 3 de 3
    • Carfully slide in the M.2 into the slot
    • Make sure to align the pins properly to avoid damaging them
    • Make sure you are installing a M-Key (5pin) M.2, A B-Key or a B&M-Key is not supported
  7. ROG Strix G16 (G614J) M.2 SSD Replacement, Screwing In 1/2: paso 7, imagen 1 de 2 ROG Strix G16 (G614J) M.2 SSD Replacement, Screwing In 1/2: paso 7, imagen 2 de 2
    • Press down on the M.2
  8. ROG Strix G16 (G614J) M.2 SSD Replacement, Screwing In 2/2: paso 8, imagen 1 de 3 ROG Strix G16 (G614J) M.2 SSD Replacement, Screwing In 2/2: paso 8, imagen 2 de 3 ROG Strix G16 (G614J) M.2 SSD Replacement, Screwing In 2/2: paso 8, imagen 3 de 3
    • Align the M.2 with the screwdriver hole
    • Screw in the M.2
  9. ROG Strix G16 (G614J) M.2 SSD Replacement, Reapplying the Tape: paso 9, imagen 1 de 2 ROG Strix G16 (G614J) M.2 SSD Replacement, Reapplying the Tape: paso 9, imagen 2 de 2
    • Reapply the tape
    • If you have removed the tape and you dont want to reapply it you may skip this step
  10. ROG Strix G16 (G614J) M.2 SSD Replacement, Reinstalling the backplate: paso 10, imagen 1 de 1
    • Align the backplate and firmly press down on the edges
  11. ROG Strix G16 (G614J) M.2 SSD Replacement, Screwing in: paso 11, imagen 1 de 1
    • Screw in all the PH0 Screws
    • Short Screws
    • Long Screws
    • Captive Screw
Conclusión
Enjoy!
7 personas más completaron esta guía.
Artem Ivat
Miembro Desde 02/05/20
3,513 Reputación
13 Guías creadas
Equipo
Kid fixers Miembro de Kid fixers
Community
Miembros de 202
291 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 78
Ultimos 30 días: 368
Todo El Tiempo: 4,558
