Introducción
If the drill does not turn on after pressing the trigger or it does not stop turning even after you release the trigger, the switch assembly might be damaged. This guide will provide guidance to the process of replacing a broken switch assembly in a RIDGID R860052.
Qué necesitas
Use a T10 Torx screwdriver to unscrew the ten screws on the information label side of the drill.
Una persona más ha completado esta guía.
