Saltar al contenido principal
RIDGID R84015 X2 Planetary Gear Replacement Guide
Qué necesitas
  1. RIDGID R84015 X2 Planetary Gear Replacement Guide, RIDGID R84015 X2 Case Removal: paso 1, imagen 1 de 2 RIDGID R84015 X2 Planetary Gear Replacement Guide, RIDGID R84015 X2 Case Removal: paso 1, imagen 2 de 2
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Planetary Gear Replacement Guide: paso 2, imagen 1 de 1
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Planetary Gear Replacement Guide: paso 3, imagen 1 de 2 RIDGID R84015 X2 Planetary Gear Replacement Guide: paso 3, imagen 2 de 2
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Planetary Gear Replacement Guide, Planetary Gear: paso 4, imagen 1 de 1
    • Prepare to remove the gear chamber.
    • Using the Phillips #2 screwdriver, unscrew the four screws at the rear of the plastic gear chamber.
  5. RIDGID R84015 X2 Planetary Gear Replacement Guide: paso 5, imagen 1 de 2 RIDGID R84015 X2 Planetary Gear Replacement Guide: paso 5, imagen 2 de 2
    • Remove the motor from the drill by gently pulling the motor away from the gear chamber.
    • NOTE: Handle the gear chamber with caution as the gears are now loose.
  6. RIDGID R84015 X2 Planetary Gear Replacement Guide: paso 6, imagen 1 de 1
    • Remove the plastic gear chamber.
    • Using the Phillips #2 screwdriver, remove the four screws that attach the plastic gear chamber.
  7. RIDGID R84015 X2 Planetary Gear Replacement Guide: paso 7, imagen 1 de 2 RIDGID R84015 X2 Planetary Gear Replacement Guide: paso 7, imagen 2 de 2
    • Remove each component from the gear assembly. Replace components as needed.
    • Reassemble the drill following the gear replacement instructions in reverse order.
Linea de Meta
4 personas más completaron esta guía.
Evan Long
Miembro Desde 04/15/10
262 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 15-48, Garner Spring 2010 Miembro de Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 Miembros
10 Guías creadas
Un comentario
Very helpful, thank you! I was not sure how to detach the motor from the gearbox and didn't want to apply any brute force, and this explained it well.
YURIY - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 19
Todo El Tiempo: 6,261
