Saltar al contenido principal
RIDGID R84015 X2 Disassembly
Qué necesitas
  1. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: paso 1, imagen 1 de 2 RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: paso 1, imagen 2 de 2
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Disassembly: paso 2, imagen 1 de 1
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Disassembly: paso 3, imagen 1 de 2 RIDGID R84015 X2 Disassembly: paso 3, imagen 2 de 2
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Disassembly: paso 4, imagen 1 de 1
    • With your drill taken apart, move your attention to the trigger and forward reverse switch.
  5. RIDGID R84015 X2 Disassembly: paso 5, imagen 1 de 1
    • Check to see that the forward reverse switch isn't broken.
    • NOTE: small tab on trigger fits into groove on forward reverse switch
  6. RIDGID R84015 X2 Disassembly: paso 6, imagen 1 de 1
    • With the battery attached, check that the wires work when the trigger is pulled.
    • Put multimeter wires here.
    • If wires work and drill doesn't, the problem is with the motor.
  7. RIDGID R84015 X2 Disassembly: paso 7, imagen 1 de 1
    • Make sure plastic is not broken and switch is not stuck.
Linea de Meta
2 personas más completaron esta guía.
Brian
Miembro Desde 04/12/10
97 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 15-48, Garner Spring 2010 Miembro de Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 Miembros
10 Guías creadas
Un comentario
I was able to diagnose and fix my problem with my black and decker following your instructions. TY
boxingchaos2011 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 24
Todo El Tiempo: 13,623
