Introducción
If the trigger in your Worm Drive Saw won’t respond when pressed or appears to be broken, use this guide to remove and replace your trigger switch and trigger. All you need are the standard Phillips 2 Screwdriver and Torque 20 Screwdriver, in order to remove the two types of screws involved with this replacement.
Qué necesitas
Place the Worm Drive Saw down and adjust the base plate, so that way the main housing assembly and handle set is easily accessible.
2 personas más completaron esta guía.
